Hosting a webserver from behind a router
Studiosoft
Message 3 of 3
I hope I have posed this question in the right place.
I have set up a nginx server on a spare machine at home. I am only using it for dev so the limited bandwidth I have isn't an issue. I can access the server remotely and I can access it via the internal IP address within the LAN. Is it possible to configure the router so I can access the server via the domain name from behind the router. I can use an external proxy to achieve this but it introduces all kinds of cross origin problems.
Website designer
Studiosoft
Message 1 of 3
Thanks Keith, I thought as much, I can manage using the internal IP address for now but i just thought I would check rather than chase shadows for the rest of the day.
Website designer
Message 2 of 3
Hi Keith,
No, you can't. The vast majority of TalkTalk routers consider traffic going out from a device to the internet & back into the router again (NAT Loopback) as a security risk and blocks it.
