on 18-02-2024 02:55 PM
I'd like to use my Talktalk router in default configuration, disable wifi and set a new IP address so I can use a new router connected by ethernet. I have no idea what I'm doing, very non tech. So, apologies if the language or explanation is wrong. I am currently logged into router admin and trying to fathom how to disable wifi etc. Any help is appreciated.
End goal is to have a new router set up (TP Link 3000) and have different networks. Private, guest etc.
Thanks in advance
Stef
on 18-02-2024 09:47 PM
No, it can't be anything, you need to abide by the rules of IP networking, it must be an address on a different subnet. What is the IP address & subnet mask of your TP-Link?
on 18-02-2024 04:39 PM
@KeithFrench Not sure on new IP address? can it be anything? if so would 192.168.1.12 be possible for the TT router? it is a Sagemcom FAST 5364-3
on 18-02-2024 03:52 PM
Hi @stefrunner
Thanks for creating a thread for this. What IP address did you want in the TT router and most crucially what make/model is it?
