Internet connection keeps disconnecting
Donkey88
Message 8 of 8
Internet keeps disconnecting. Had this issue just over a month ago and was sent a new router. This seemed to solve the issue, but now it has started again. Having to turn the data off my mobile phone as didn't realise I was using my data when the WiFi to the Internet was going off.
7 REPLIES 7
Message 1 of 8
Hi Donkey88
KeithFrench is one of our valued Community Stars and can help with a range of issues related to wireless and networking. At times he may ask you to send him test results via a Private Message to help analyse/diagnose an issue.  Although Keith does not work for TalkTalk, he very kindly shares his time and knowledge to help with others.  If you need further help or, if we need to take any details such as personal information about your account like phone numbers, account numbers etc.  one of the TalkTalk team will jump in and help out.
Message 2 of 8
This is exactly the help I can give, plus it is over & above that which TalkTalk can provide.
Donkey88
Message 3 of 8
Thanks again Keith for your reply.  Speed appears fine. Have been with Talk Talk for years and never had an issue so maybe it is interference from other networks.  Will log a call with Talk Talk to see if they can investigate the issue.  I appreciated all the advice you have given me
Message 4 of 8
Have you had TalkTalk’s Wi-Fi optimisation disabled on your Sagemcom FAST5364/5464 router? When this is enabled, as it is by default, it has the power to override any Wi-Fi configuration changes that I might suggest that you need to make. This will not help rectify this type of problem if Wi-Fi Optimisation is allowed to change my suggested settings. Only TalkTalk can do this for you, you cannot do it yourself. If not, just request they disable this for you in your reply.
Donkey88
Message 5 of 8
Hi Keith, thanks for your reply.
My router is a Sagemcom and I am on the fibre 35 package. The light stays constant white even when the Internet is not connected. I do not have any wired connections. Recently had a new router and wires which did solve the issue for a few weeks it seems unless I hadn't noticed it. It's definitely not an issue with my mobile phone as my phone is fine on the WiFi at work. . My phone keeps saying phone is connected but without internet
Chris-TalkTalk
Message 6 of 8
Hi Donkey88,
In addition to answering Keith's questions can you please update your community profile to include your:
  • Name
  • Telephone number
  • Alternative contact number
Message 7 of 8
2. What package are you on?
3. What is the exact status of the lights on the front of the router when this happens?
4. If you have any wired connections, are they affected in the same way as wireless ones?
