Unable to connect to some websites
AdeleaSN
Message 24 of 24
I am having trouble connecting to some websites this morning:
poelab.com
github.io
Using TalkTalk I get:
This site can’t be reached
poelab.com took too long to respond.
Try:
  • Checking the connection
  • Checking the proxy and the firewall
ERR_CONNECTION_TIMED_OUT
Check your internet connection.
If I switch to using my virgin media connection they connect and work fine.
23 REPLIES 23
Message 1 of 24
@AdeleaSN that's good news.
Thanks for letting us know.
Message 2 of 24
The issue seems resolved now.
Message 3 of 24
Hi @cltrr
Please refrain from continually posting on other people threads as this delays our response and can make it difficult for others to follow the thread.
This is also against community guidelines.  If you continue I will Ban you from this community.
Message 4 of 24
@cltrr you have been asked by 3 separate people to follow the forum guidelines.
This thread belongs to @AdeleaSN and unless staff feel so inclined will be the ONLY person to get a specific reply.
Continually posting on another's thread is seen as spamming under forum guidelines and can, in certain circumstances, result in a ban.
Guidelines can be found here
https://community.talktalk.co.uk/t5/Announcements-Guidelines/Community-Guidelines-Updated/td-p/13256...
Message 5 of 24
@Chris-TalkTalk Are you using a different gateway by any chance? It might be that only certain a gateway(s) are affected by this issue.
The one to look at is typically the first hop after you ISP router which is considered the gateway.
Maybe do a traceroute to compare your path to the sites mentioned. Here's mine and as you can see there's no path to the host still:
Github.io TracerouteGithub.io Traceroute
Poelab TraceroutePoelab Traceroute
Message 6 of 24
@DJI_MINI_2_SE wrote:
You will push this thread  further down the queue not "Bump it to the top" as support work on oldest threads first
Well it seems to be working as staff just replied to the thread a moment ago.
DJI_MINI_2_SE
Super Duper Contributor
Message 7 of 24
"Maybe we can ask OP if he minds us responding to his thread and keeping it bumped at the top"
Unfortunately you seem to misunderstand how the forum works!
I pointed out the reason you need to open your own thread and Gliwmaeden2 asked you to do the same  if you keep disputing the forum rule  you will push this thread  further down the queue not "Bump it to the top" as support work on oldest threads first, please open your own thread as instructed by Gliwmaeden2 and if  you don't like the forum rules feel to take that up with staff in the relevant forum.
Message 8 of 24
Hi AdeleaSN,
I've checked the two websites and I seem to be able to access them OK, are you still experiencing the same issue?
Message 9 of 24
@DJI_MINI_2_SE Unfortunately nothing specific can be asked in this case, this is affecting many customers not a single one.
All the issues related to this are identical. It's not your usual issue where every customer is experiencing something different.
It's up to TalkTalk engineers to fix the peering issue, either on this gateway or return us back to the usual BNG/Gateway.
7 out of the past 15 replies to this thread have been in relation to not using the same thread, so I'd suggest that you/others are derailing the conversation on the actual issue rather than me/others who have replied.
Maybe we can ask OP if he minds us responding to his thread and keeping it bumped at the top?
Message 10 of 24
Yes - there's also the fact that the original poster may not appreciate getting their inbox swamped with notifications. Better if affected customers can follow forum guidelines  - these are there for a reason and from long years of experience!
DJI_MINI_2_SE
Message 11 of 24
Not sure what the obsession is with creating a new thread for an identical issue, very weird.
Especially when customers are already annoyed with the issue, instead of addressing the actual issue you're telling us how to use the forums.
The reason is if staff usually need more information from  member some of this may be private or they may need to  ask specific questions which may not be able to be answered immediately  it  can make it hard work when several customers are all using the same thread far better to keep them separate hence the request.
DJI_MINI_2_SE
Message 12 of 24
@AdeleaSN wrote:
Do they work when using the links below -
PoELab
GitHub Pages | Websites for you and your projects, hosted directly from your GitHub repository. Just...
Message 13 of 24
@DJI_MINI_2_SE Staff have already responded to another thread on the issue.
Our network teams are currently investigating these reports.
DJI_MINI_2_SE
Message 14 of 24
"I am also having an issue with access to github.io. Can we please get clarity on the issue? It is not acceptable as some of us work from home and need this access.
I will seriously consider leaving talk talk. Abysmal service"
Wow you hijack another members thread ask for clarity and before giving time for a staff to respond throw your toys out of the pram and  call it abysmal service and say you are considering leaving,  as already explained  support staff will only deal with the customer who opens the thread you need to open your own.
Message 15 of 24
No, Im not using the Eero router. I couldnt see how to turn off its DHCP functionality, so it went back into its box right away.
Message 16 of 24
@cltrr, the response is NOT the same if everyone piles on one thread - multiple replies slow down the progress of the original post in the workflow to reach staff support, so delays the response to the OP.
Then it's recorded as only ONE incident because it has only one topic posted.
That's why it's not helpful to post "me too" comments. If everyone experiencing an issue posts their own topic that algorithm will calculate a much more realistic assessment of the scale of the problem and a resolution will be prioritised.
Message 17 of 24
@cltrr this is a requirement of the forum, one thread per person, unless staff instruct otherwise.
efgrdwefgr
Message 18 of 24
I will seriously consider leaving talk talk. Abysmal service.
Message 19 of 24
@fr8ys The issue is identical. It would make no sense to create multiple threads related to the same exact issue.
The response that would be given would be the same across the board as is the issue.
Message 20 of 24
@dennisjs @cltrr
Please start your own thread as each case is considered unique and it is easier for support to be given to one person per thread and also less confusing.
To start your thread click the Browse button, then Help With Your Service and select the appropriate category. You will then see a Blue Button "Start A Topic"
Please also note that you should only post back on that thread and not start another on the same topic as multiple posts cause delay to you and others seeking help.
Thank you
