Internet dropping
Isabelsilva1
Message 6 of 6
  • For a few days I have been contacting talktalk about my dropping wifi. I have told them about my modem internet light is always off even when I have wifi. They keep saying that is not at problem and the dropping signal will be fixed in a couple of hours. Once again is not fixed and signal went down again after 4 hours. Do you think might be a problem with the modem?
5 REPLIES 5
Message 1 of 6
Hi @Isabelsilva1
This is the latest update on this fault.
Update 8:40PM  December 17th 2024 - Our team are in the process of applying a solution to all impacted Wi-Fi Hubs and aim to resolve this by tomorrow morning.
Message 2 of 6
Hi Debbie
Yes thats right. The internet keeps dropping and there is no change in the lights in the modem or in the  router. In my modem there is 4 lights, the internet is always off that's why I'm not sure if is anything wrong with it and if that's the reason for the internet keep dropping.
Message 3 of 6
Hi @Isabelsilva1
Sorry for the confusion, do you mean the white light stays on the router even when the connection has gone off?
Isabelsilva1
Message 4 of 6
Unfortunately still the same. And due to my shifts at work for the next few days I can't be in contact with talktalk at minute.
Chris-TalkTalk
Message 5 of 6
Hi Isabelsilva1,
I'm sorry to hear that you've been experiencing problems with your service. How has it been since you posted on Saturday?
