Internet keeps on dropping out
Berkoboy
Message 18 of 18
I am having the same problem as a number of others - my internet keeps on cutting out then 5 or so minutes later restores itself. This is happening dozens of times a day - and has been particularly bad in the last few days .
I had Openreach at the property a few weeks ago to fix a speed issue - and when connected I do now get Fibre 65 rated Mbps . Tested as REP 14451453
The TalkTalk error page says "intermittent sync".
There have been no changes to any of my equipment or cabling since the Openreach visit. I rather not go through the Helpdesk  same old same old  checks of with/without microfilters/ ethernet cable checks / router reboots / faceplate removal - I can't see any point . Either its the router (unlikely ) or some issue outside the property
17 REPLIES 17
Message 1 of 18
Please return to the message board and click on start a topic to begin your own thread, @Liggins78.
Also complete your profile details. Go via your avatar, settings, drop down menu....add your Talktalk phone number or account number in Personal Information. Scroll down to find the button to SAVE CHANGES.
Liggins78
Message 2 of 18
I been sent a new router and still the same problem. Connect for 5 to 10 minutes then drops out again.
Message 3 of 18
Morning @Berkoboy
How's the connection/speed been over the weekend?
Message 4 of 18
Hi @Berkoboy
We will check back in with you on Monday to see how you getting on.
Berkoboy
Message 5 of 18
Hi , The drop-outs seemed to have stopped ( or a least now down to 1 or 2 a day ) . So I haven't persisted with the new router and I will return it to TalkTalk. I think the problem lies outside the property - especially as my speed has now dropped back beneath the guaranteed Fibre 65 quote . 41 Mbps just now . Openreach were here before for the same problem a few weeks ago and say they found and fixed a couple of loose connections which seemed to have solved the problem . But I am now almost back where I started ( speed is slightly better than first time around ) . I suspect the issue is just the poor quality of the old BT infrastructure between my house and the green junction box which is less than 100 meters away or in the green box itself.
I have just renewed my Fibre 65 contract .  I will test speed over the next few days ,  clearly I will be expecting this to be resolved in the not to distant future as the moment I am not getting what I paid for.
Message 6 of 18
Good morning,
Ok thanks for the update and please let us know how you get on.
Berkoboy
Message 7 of 18
Hi , I tried the replacement router but it didn't go smoothly . I decided to go wi-fi rather than the TP-link (via the power supply) as the old set-up.  The connection was only intermittent . The router showed the steady white light as connected but Windows settings showed disconnected - and Edge/other connected programs errored as 'unable to find address/DNS not found' etc. It did connect for  short periods but I gave up after 1/2 hour and went back to the old router .  As mentioned the old router is still disconnecting but now in single figures per day rather than dozens - not ideal but  an improvement.
My PC wi-fi USB dongle  is round the back of  the metal PC case and not in line of sight to the router - so I will try again with a front facing  port in the next day or so.
Message 8 of 18
How are you getting on?
Michelle 🙂
Message 9 of 18
Good morning,
No problem 🙂 We'll check back in with you next week.
Berkoboy
Message 10 of 18
Hi ,
Apologies - I have a few important things to do remotely - so I haven't yet tested the new router. I didn't want to risk a problem occurring .
As mentioned dropouts are now down to single figures per day without the change. I plan to test the new router on Sunday .
Message 11 of 18
Morning @Berkoboy
Message 12 of 18
Good morning,
Thanks for letting us know. We'll check back in with you in a few days to see how you're getting on and how the connection has been.
Message 13 of 18
New router received - I will fit it tomorrow . Thanks . Having said that the drop-outs have diminished substantially over the weekend and  only one so far today.
Message 14 of 18
Message 15 of 18
Hi @Berkoboy
If you experience the same fault (connection dropping) with the new router then the next step will be an Openreach engineer visit.
Debbie 🙂
Message 16 of 18
Hi Debbie ,
My router is left on  24/7 . My router is the original one from some years ago so no new router has been tested . Happy to test a new one .
Message 17 of 18
Hi @Berkoboy
The line test hasn't detected any faults but I can see a high number of re connections on the line.
Is the router at the test socket at the moment?
Have we recently sent you a new router for testing?
