Internet speed dropped - sync down substatially after being away and turned off
AbjectBlitz
Message 4 of 4
I've been away for 3 weeks and the router was turned off.
I've come back and the sync speed has dropped substantially , well over half of a drop.
Used to get regular 60-70 Mbps and now getting a frustrating 20.
Been 60-70 for many years -whats going on?.
Can you please check the sync rate and bump it back up please.
Cabling has been checked. reseated etc.
Please let me know if  you need more information.
Thanks,
Martin
3 REPLIES 3
Message 1 of 4
Hi there @AbjectBlitz, I will look into this for you. Please confirm if you are messaging us from home.
AbjectBlitz
Message 2 of 4
Currently router showing Status
Connected
Current speeds
Download
20.3 Mbps
Upload
3.7 Mbps
Never seen such a drop after being off for a few weeks - is this normal to lose previous sync?.
Line 1
DownstreamUpstream
203353699
193863699
6.305.60
39.200.00
11.101.40
Message 3 of 4
You may need to give it a couple of days or so with a constant connection for DLM to do its thing.
EDITED after re-reading, apologies!
