Please disable wifi optimization
Mechismo
Message 8 of 8
Please disable wifi optimization - I cannot manually select a channel on my new replacement router. thanks
7 REPLIES 7
Message 1 of 8
Hi there @Mechismo just checking if the issue has been resolved after @KeithFrench has advised?
Phili
Message 2 of 8
Hi @Mechismo
In other words, I offer a free, impartial analysis of your Wi-Fi network and will try to help you optimise your Wi-Fi connection. The next stage involves sending out a guide to help you get me some important diagnostic results so that I can analyse them for you and recommend changes to your router configuration to solve them.
The information below is provided by TalkTalk. For confirmation, please contact @Lorrainef.
If you need further help or if we need to take any details such as personal information about your account like phone numbers, account numbers, etc, one of the TalkTalk team will jump in and help out.
Message 3 of 8
@Mechismo, it is not possible to switch off WiFi optimisation. Since you last had this issue Talktalk has changed its policy, claiming that it affects aspects of service. Just can't be done any more.
If @KeithFrench has time, he may be able to advise you as to how to get the best from your wifi.
Message 4 of 8
No such setting on my router
Message 5 of 8
Hi thanks but it just resets 10 minutes later to "optimise" which does the opposite. I had an update on my old router that prevented this.
siphosethu-TT
Message 6 of 8
Hope this will help. Thanks
Settings > Wi-Fi > Advanced and uncheck Wi-Fi optimization.
siphosethu-TT
Message 7 of 8
Here's a few steps on how to do it. 😇
1. Open a web browser and type your router’s IP address into the address bar.
2. Enter your router’s username and password.
3. Open Wireless Settings in your router.
4. Choose your Wi-Fi frequency band.
5. Click Channels to change your Wi-Fi channel.
6. Make sure to hit save and apply
