on 01-07-2025 01:10 PM
For TalkTalk moderators, technical staff etc. - Please could you arrange to disable the wi-fi optimisation feature so that I can improve the coverage for the whole house rather than at the location of the hub. I expect you will need me to provide a phone number (or other details) but I don't want to post those here.
Many thanks,
Antony
on 01-07-2025 03:14 PM
WiFi Optimisation can no longer be disabled; that was a company decision by TalkTalk. However, I can offer a free, independent investigation of your WiFi network. In most cases, the problem is caused by something else.
Slow speed, intermittent dropouts, breaks in the signal or no signal on some or all devices or no internet access might be caused by Wi-Fi interference from other local networks, which can also lead to a permanent reduction in speed. No ISP can be responsible for your local environment; this is mainly a byproduct of the popularity of Wi-Fi.
In other words, I offer a free, impartial analysis of your Wi-Fi network and will try to help you optimise your Wi-Fi connection. The next stage involves sending out a guide to help you get me some important diagnostic results so that I can analyse them for you and recommend changes to your router configuration to solve them.
on 01-07-2025 01:25 PM
thank you
on 01-07-2025 01:18 PM
Hi @montymontana your post has been escalated and you should hear soon. In the meantime please check your community profile and add your landline number and/or account number so your account can be identified. Please don't post personal information here.
https://community.talktalk.co.uk/t5/user/myprofilepage/tab/personal-profile:personal-info
Only staff can arrange this and be aware it resets after every router reset or firmware update.
