on 03-12-2025 01:55 PM
I had an email today about the notification that TalkTalk are going to start charging for this service. I never use the phone, so I tried to disable the Callsafe feature as the instructions on the email. However, there is no option for Callsafe or to disable this feature. Please help?
04-12-2025 07:10 AM - edited 04-12-2025 07:14 AM
@jazzman3 CallSafe has been disconnected, I have just checked your account.
03-12-2025 05:25 PM - edited 03-12-2025 05:27 PM
Also worth taking a look at this area of My Account, @jazzman3:
https://help-centre.talktalk.co.uk/Manage_account/Offers_and_Upgrades/Add_or_remove_a_Boost
Check what is or isn't ticked in there. It's probably worth adding Last Caller Barring [which you wouldn't have been able to use while Callsafe was selected].
on 03-12-2025 05:22 PM
It seems to be so, @jazzman3:
https://help-centre.talktalk.co.uk/Telephone/Telephone_security/About_CallSafe
on 03-12-2025 04:59 PM
I have tried another browser and found a setting for CallSafe. Just looking for advice is it just a matter of turning the CallSafe setting to off and CallSafe will be removed from your account
03-12-2025 02:15 PM - edited 03-12-2025 02:16 PM
Please note that there is no way for me to switch it off from my end, try contacting the better value team perhaps they might be able to help. Thanks
03451720088
Monday - Friday 9am - 7pm ; Saturday - 9am - 6pm ; Sunday - Closed
on 03-12-2025 02:01 PM
Hi there @jazzman3, I'll have this this looked into for you please bare with me while I investigate. Thanks
