Keep Losing Wifi signal
on 12-03-2024 10:20 AM
Message 5 of 5
I have a Sagemcom router which over the last few months keeps "dropping off". I have done the usual, switching off, unplugging, rebooted and changed the wifi channel to virtrually every option available, and it still keeps disconnecting. The white light is continually on and does not change when the signal disconnects and my PC which is connected with an ethernet cable does not have any issues and continues to work perfectly when the wifi signal disconnects to other devices, for example, Alexa, smartpad, internet radio and smart phone. The router is in the exactly the same place as it has always been.
Some advice would be appreciated.
Labels:
- Labels:
Router
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
4 REPLIES 4
on 15-03-2024 07:34 AM
Message 1 of 5
Hi nigelnw
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 12-03-2024 10:44 AM
Message 2 of 5
Hi nigelnw
I've ordered a replacement router, please allow 24-48hrs for this to arrive.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 12-03-2024 10:39 AM
Message 3 of 5
Unfortunately I don't have a spare router, so if you could send me one, that would be appreciated.
Thanks for your prompt response.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 12-03-2024 10:28 AM
Message 4 of 5
Morning nigel,
Thanks for your post and I'm sorry to hear this. I've run a test on the line now just to rule out any faults and this is clear. The router also has the most recent version of firmware. Do you have an alternative router that you could test with? If not then we can send a replacement router for testing purposes.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
