on 18-11-2025 09:24 PM
For a few weeks now I seem to lose wifi for a few minutes most days when using my laptop or phone. I have the Huawei Router HG635 and am wondering if it needs replacing as it is no longer supported. I have tried contacting the online support but can't get an agent to answer.
3 hours ago - last edited 3 hours ago
Perfect! I will be able to send through the order for you @Bella2025 please add your delivery address under private note on your profile and let me know or you can send me a private message with the details.
3 hours ago
Hi @Philile-TT
I totally agree with you.
5 hours ago
@KeithFrench I think it best we replace it and @Bella2025 will let us know if it does any difference.
6 hours ago
If it was down to me I would have replaced your router at the start.
Alas the default settings in a router are not always the best. However, until I see what is happening to your WiFi network via my diagnostics, I do not know how your router is configured.
7 hours ago
@Bella2025 the router you have is quite old this could be the reason, please send me a private message with your address.
7 hours ago
Hi @Bella2025 I will have a look at your router.
yesterday
I have changed the bandwidth to 20MHz for the 2.4GHz frequency band. It was about 9:30 last night when I lost connection. I should point out that the router settings I have never adjusted apart from changing my password. These settings used must have been default when I set up the router following the instructions given by Talk Talk. I will let you know if I have further issues. Thanks.
yesterday - last edited yesterday
Hi @KeithFrench and thank you very much for helping out:)
yesterday
Hi @Bella2025 & @nambuso-TT
You are using a 40 MHz channel bandwidth on your router, which you should never do. This is because, without getting technical (I will willingly do so if you require), you are using up 9 out of the 11 available channels. This means that other networks will interfere with you, plus you are causing interference for every other router in the 2.4GHz band in your area. This not only slows you down but also everyone else trying to use this band.
If you log into your HG635 & go to:-
Home Network > Wireless Settings > Advanced Settings
Then, under 2.4GHz Frequency band, set .11n bandwidth to 20MHz only.
Moving on from that, your 2.4GHz signal is varying in signal strength quite a bit, with some particular drops at 21:32 & 21:33, I don't know if these times coincide with your problems. However, I expect that with you using a 40MHz vchannel bandwidth, this is the most likely cause of these drops. However, I can't be certain without another snapshot when/if you have problems with the router set to 20MHz only.
Thank you very much for the support, @KeithFrench. @Bella2025, please let us know if you would like us to conduct some checks to identify the cause of the issue and find a potential solution. Additionally, you've mentioned that your router no longer receives updates please note that this should not prevent your router from providing internet access. Thanks
yesterday
Hi @Bella2025
Thanks for these, I will have a look a bit later this morning & get back to you.
Hi there @Bella2025. I am very sorry to hear this. I will look into this for you. Please confirm if you are messaging us from home. Thanks
Wednesday - last edited yesterday by KeithFrench
I lost wifi again last night so I collected the files again. Can you have a look please. I will send the code.
on 25-11-2025 11:06 AM
Thank you @KeithFrench
on 25-11-2025 10:59 AM
Hi @Bella2025
Those instructions were for the DG8041W, not the HG635. It was just that the DG8041W has stability issues and if you had that one, I would have asked TalkTalk to consider replacing it. The HG635 is even older, but does still works OK. If you wanted to get a new router, you could ask TalkTalk to replace it for you, but currently, you would probably have to pay for it. Currently, I do not see any technical reason to need a new router. When your contract is next up for renewal, it would make sense to ensure that they give you a new router.
As per my previous email, please can you try moving the 2.4GHz channel to 11 & see how it goes? To do this, log into the router & go to:-
In the 2.4GHz section, change the channel there.
If it does fail again, please can you get me a snapshot from Wi-Fi Scanner at that time?
on 25-11-2025 07:13 AM
Thank you @Gliwmaeden2 and @KeithFrench for assisting.
24-11-2025 09:00 PM - edited 24-11-2025 09:00 PM
@Bella2025, the router DH8041W is simply another Huawei router, which used to be described as the Hub Black, and was actually similar in appearance to the Sagemcom routers that Talktalk called Hub 1 and Hub 2 .... they are now on to Hub 3.
Your HG635 is an older router still, also by Huawei. Important to know it was that one for Keith to help with the diagnostics.
on 24-11-2025 07:16 PM
Hi Keith,
My router is Talk Talk's Super router HG635. I don't know what DG8041W relates to. I didn't have any issues when I did the reports. I have logged into my router but can't see the settings you mentioned. I can't find the user log page. If I click on the internet section I have connection mode, internet connection, Firewall, Internet services, port forwarding and routing rules down the left hand side. There is a maintain option on the top right. If I click on that there are diagnosis tools and Ping and Traceroute. Do you mean there?
on 24-11-2025 09:49 AM
Hi @Bella2025
There are two problems that I can see:-
Dashboard > See Internet Settings > Manage advanced settings > Advance Configuration > Maintenance Diagnostics > User Log
Was the snapshot taken at a time when the Wi-Fi was actually dropping?
on 24-11-2025 09:29 AM
Hi @Bella2025
Thanks for the password, I have got all I need. I will try & look at it later this morning.
