on 27-03-2025 11:24 AM
MY UPLOAD SPEED IS 0000! Speed
on 27-03-2025 01:38 PM
Hi jontheblacksmith,
As Gliwmaeden2 has requested, can you try a different speed tester
on 27-03-2025 11:43 AM
It sometimes shows that in My Connection because it seems to only deal in whole units.
If you run the test on any other speed checker, @jontheblacksmith, what reading do you get?
My upload speeds show as eg 0.86 with Ookla independently of My Connection. If you are on Fast Broadband, the upload speed usually can't exceed 1Mbps so shows as 0 in My Connection if it's much below that.
What package are you on?
