Master socket to router
rbbrown2448
Message 6 of 6
I want to run a long cable from my master socket to my router to an external wall via my roof space and through the wall to terminate with a new slave socket and from there a short cable to my router. Can anyone advise me whether this is advisable or whether there is a more sensible alternative. Any advice would be much appreciated
Regards Roger
5 REPLIES 5
rbbrown2448
Message 1 of 6
Thanks. That sounds the best idea . Thanks for your help
Regards Roger
Message 2 of 6
Hi @rbbrown2448
One possibility if these devices are all going to be close together at the destination, is to run one Ethernet cable (not sure how long this would need to be, the max limit is 100M), then connect a small gigabit data switch (normally around £15 - £20) to it. Then run individual Ethernet cables to your devices. I would recommend Cat 6 Ethernet cable for the long run particularly,  as depending on what router you have, this should be running at Gigabit speeds. However, if you can wait, I would do what @ferguson suggests and go for full fibre if you can.
Anonymous User
Message 3 of 6
@KeithFrench - Do you have any additional suggestions please?
Message 4 of 6
Hi thanks for your response. I was thinking about putting my router close to the master socket and running an Ethernet cables to my devices. Problem is I have three Ethernet connections from my router to devices and  can't slip them between a newly fitted carpet edge and skirting. Therefore the more complicated route. Any thoughts. I have a sender but only one Ethernet outlet
Regards Roger
Message 5 of 6
With the coming retirement of the copper-based network that seems like a very complicated process for what can only be a short-term solution. If you want a wired network in your home then look to an ethernet solution.
Anonymous User
