No Internet Since Sunday 8th December. Help Please.
AnDaMi
Message 33 of 33
Hello
My internet has been out since Sunday 8th December
Flashing Amber Light on Router
three or four green lights on the small box on the wall
Have tried turning off/ on
Have tried resetting
Have tried phoning but not managed to speak to a person.
Can i get some assistance please?
32 REPLIES 32
Message 1 of 33
Thanks. Could you switch the ONT and router off and leave them off for at least 30 minutes, then switch back on and retest. Please let us know how you get on
Message 2 of 33
..neither router will boot any further than the flashing Amber lights....
AnDaMi
Message 3 of 33
Hello Chris
All 4 lights are green on the ONT
I have tried my old router ( which was working) and also tried the brand-new out-of-the-box router I was sent.
thank you
Message 4 of 33
Hi AnDaMi,
Which lights are currently on, on the ONT?
Message 5 of 33
Staff will be back on here during the day. They are on here Monday to Friday, so look out for their reply tomorrow, as there won't be support on here over the weekend.
I'll re-escalate this thread for their attention, @AnDaMi.
AnDaMi
Message 6 of 33
Hello.
So, Like I said I have had no internet for several days now. The same flashing Amber Light. Will not reset.
I was previously  told I cannot upgrade to Fibre because of the house has copper wire.
This latest outage is very, very inconvenient.
I am going to have to get a different provider if this can't be fixed. It has been two months since I had the last fault - when  i had no internet for a week.
Please can you advise?
AnDaMi
Message 7 of 33
Hello
Again I have not had any internet for 3 days. I tried using the new router and that doesn't work either.
I have turned it / off and on
I have reset and waited 15 mins
I cannot work from home ..
Can you fix this at all?
Thank you
A
Message 8 of 33
I can see that my colleague Chris sent the replacement router in relation to a fault. If you log into your My Account does it show any information regarding a full fibre upgrade?
AnDaMi
Message 9 of 33
Hi - so I got an email saying my service has been upgraded to full fibre and I'll be sent a router.
So now I am a bit confused - was my internet off because it was being upgraded? and is this router the one you sent me to test or one I have been emailed to say I need for full fiber? I didn't ask for an upgrade...  just  a bit confused 🙂
Message 10 of 33
Great, thank you 🙂 I'll check back in with you on Wednesday just to make sure that everything is still ok.
AnDaMi
Message 11 of 33
Hi Michelle. Yes, of course.
Many thanks A
Message 12 of 33
Good afternoon,
Thanks for the update. Would it be ok to keep hold of the replacement router just for a few days to see how the connection compares and to ensure that this is fully resolved?
AnDaMi
Message 13 of 33
Hello
The router hasn't been delivered yet; but I got an e-mail to say it was on it's way.
However - my internet has gone on-line again, almost at the exact time it went off a week ago - so shall I simply return the router you have kindly sent? - i won't even have to unbox it.
I don't know why it came back; I didn't even reset it...
Many thanks
A
Message 14 of 33
Just checking back in to see if the replacement router has arrived yet?
Message 15 of 33
Good afternoon,
We'll check back in with you first thing next week to see how you're getting on.
AnDaMi
Message 16 of 33
Thank you.
Message 17 of 33
Hi AnDaMi,
I'll order a replacement router to test with. It should be with you within a couple of working days
AnDaMi
Message 18 of 33
Hello
It's still not working. Tried restting several more times.
It's been nearly a week now; I can't work from home, nor do much else at home...
If it is the router, do you send me a replacement?
many thanks
A
AnDaMi
Message 19 of 33
Hello
I tried that and it is still not working and the router is flashing Amber.
thanks A
Message 20 of 33
How are you getting on?
