on 22-11-2021 09:18 PM
I've had no internet for four days now, just a constant flashing amber light. A fault was found two days ago and apparently an openreach engineer came and fixed the fault yesterday. My talk talk box is still flashing amber constantly, no white light. Customer service now say there is no fault and the issue is to do with my home setup. Please see below things I have tried:
- Turned router off and on
- Reset router using the pin hole button
- Used the test socket
- Used a different grey dsl broadband cable
- Used a different microfilter
- Even checked the wiring within the master socket
All result in the exact same, flashing amber light, that occasionally turns off for a second before flashing again. The amber light probably flashes for about 45 minutes before the router just turns itself off. Is this a router problem? That is the only thing left I can think off, but TalkTalk want me to pay £50 for an engineer to come, which I'm not doing. Does anyone have any advise on what I can do?
on 29-11-2021 10:13 AM
The compensation scheme is a joke! I have had little to no broadband service since the start of the pandemic and for £29+ a month I was only given a £10.00 Amazon voucher as a goodwill gesture... TalkTalk keep sending out Openreach engineers who always tell me the problem is not with their equipment but the service provider; so don't expect much because you'll get almost nothing!
on 29-11-2021 07:31 AM
I'm sorry for the delay. I've included our help guide below which contains more information on how this works.
About your auto compensation credit
on 27-11-2021 02:07 PM
Forum staff don't have responsibility for the automatic compensation system, @ajackson96. There is also a delay before that is paid, so they won't be able to chase it for you for 30 days at the absolute minimum.
The compensation scheme doesn't actually specify whether the problem has to have been with the line or the router as the cause - just total loss of service for x days etc.
All anybody can do is wait - probably into the New Year, given that 30 days gets us into the Xmas period, and you have been forewarned that there are industry-wide delays in the delivery of compensation.
I am afraid that you simply have to wait and see before chasing it up.
It is possible to have discretionary goodwill gestures, but you are likely to have to wait for the automatic system to take its course before anyone can consider that.
on 27-11-2021 01:07 PM
This is a tricky one. If the fault was with the router rather than the actual internet service, I'm not sure if they will pay compensation for that.
on 26-11-2021 08:08 PM
Thank you
Hi Debbie,
Thanks, the new router solved the problem proving the old router was at fault. Apparently compensation is automatic once I'm back online, is there a way to check this?
on 25-11-2021 06:54 AM
HI Alex
The router was showing as dispatched on 23/11. If you haven't received this by this afternoon then please let us know.
on 24-11-2021 07:21 PM
@ajackson96 compensation should be automatic once the fault is fixed and the days without service are known.
https://community.talktalk.co.uk/t5/Articles/About-your-auto-compensation-credit/ta-p/2326583
on 24-11-2021 05:50 PM
Hi Debbie,
Do you know the progress of this router being delivered please? Unless they deliver it overnight tonight it will not come within 48 hours. Could you let me know how I can claim compensation as well please as I will have been without internet for over a week now.
Thanks,
Alex
on 23-11-2021 07:14 AM
Hi Alex
No problem 🙂 The router is on its way, please allow 24-48hrs for this to arrive.
on 23-11-2021 07:01 AM
Hi Debbie,
Yes please that would be great! I think it must either be the router or the openreach engineer didn't fix the initial fault properly, as everything else is fine. The router has been working fine for 11 months up until this point.
Thanks,
Alex
on 23-11-2021 06:54 AM
Hi ajackson96
Would you like me to send a replacement router for testing so we can rule this out?
22-11-2021 09:52 PM - edited 22-11-2021 09:54 PM
Hi @ajackson96,
Do you have a landline phone you can connect to the socket to see if the phone line is working, if so can you dial 17070, this will read back the phone number for the line, can you ensure this is the number you expect (i.e. the number shown in My Account).
If there was a fault on the line that required Openreach then it probably isn't a router problem, but if the staff here did want to eliminate that as a possibility they would be able to send you a replacement router to test with.
