Patreon content delivery network blocked?
herdivineshadow
Message 7 of 7
Over the last week, whenever I try to access Patreon's website none of the images or other media (like podcast audio files) load. However when I access using a VPN, I am able to access them.
Has anyone else experienced this?
Patreon support suggested that TalkTalk might be throttling or blocking their content servers as I only experience this while using my TalkTalk connection on my laptop and phone but if I use a VPN or switch to data on my phone everything works as it should.
6 REPLIES 6
Message 1 of 7
@Shirltay1, good to hear that the workaround above worked for you.
If you need further support, please return to the message board and click on start a topic to begin your own thread.
Staff only respond to the original poster of the topic.
Shirltay1
Message 2 of 7
I have the exact same issue and it’s very frustrating. TalkTalk have said that their system has detected a virus within Patreon and the only way around this is to completely turn off Homesafe. I am now using a VPN to open any images within Patreon. I use Patreon on a daily basis for tutorials and getting to the point of considering changing broadband provider.
Message 3 of 7
Hi there @herdivineshadow, we are glad Divsec has been able to help, if you need anything else or further support, please never hesitate to reach out and we will be here to help.
-Fez.
Message 4 of 7
From the 29th of March our TalkTalk Community will move to peer-to-peer support and the TalkTalk team will no longer be here to support with queries. Don't worry we still have plenty of ways to reach out if you need to speak to TalkTalk directly. For more details check out the link here: How to contact TalkTalk Broadband - Help & Support. 03451720088
Message 5 of 7
Thanks @Divsec - had totally forgotten I could swap to using Google's DNS, although it looks like using a VPN is going to be the way forward since we're using homesafe. Hopefully TT's DNS will get over their issue with Patreon soon.
Divsec
Message 6 of 7
Hi @herdivineshadow sometimes the TT DNS servers get some odd ideas and block sites, they usually sort themselves out fairly quickly. If you use homesafe or the TT online security kidsafe etc. it relies on TT DNS servers. If you don't a change to Google DNS 8.8.8.8 and 8.8.4.4 is a quick and permanent fix.
Otherwise your VPN fix is the way to go.
