Port Forwarding port 80 and 443
oswinmurzello
Message 4 of 4
I need to forward port 80 and 443.
My router model is DG8041W
When I try to port forward I get the message:
"The configured port conflicts with the internal service port."
I’ve read in other posts here that other people have had the same problem and have had their routers replaced with an alternative router that allows the ports to be opened.
Refer:
https://community.talktalk.co.uk/t5/Security/Port-Forwarding/m-p/2874144#M22637
Is there a firmware upgrade available for DG8041W to allow port forwarding port 80 and 443 yet?
If not can you please replace my router with the model that supports this?
Oswin
3 REPLIES 3
Message 1 of 4
Hi oswinmurzello
The Sagemcom WIFI hub is on its way and a returns bag for your current router.
Please allow 24-48hrs for this to arrive. Let us know how you get on.
oswinmurzello
Message 2 of 4
@Anonymous Can I get the Sagemcom hub
Oswin
Message 3 of 4
This is a problem with the current firmware of the DG8041W, I have requested that these & some other ports be allowed to be forwarded. In the meantime, if you ask the TalkTalk support people on this forum in your reply, they may be able to offer you the Sagemcom WiFi Hub, which will forward them.
Anonymous User
