PORT FORWARDING
Radiokenny
Sightseer
Message 6 of 6
Hi all
I have a Huawei Echo Life dg8041w from  and as much as I try I cant get it to work .Am I missing something any help would do
I used 8080 port on my other TalkTalk router
Kind regards
Kenny
5 REPLIES 5
Message 1 of 6
Hi @Radiokenny
I can definitely help with port forwarding issues on all TalkTalk routers, irrespective of their support state.
Gliwmaeden2
Message 2 of 6
@Radiokenny, the DG8041W is listed among devices that Talktalk no longer supports as it cannot supply firmware updates.
@KeithFrench may well be able to help with the current issue though.
If it's not working at all, Talktalk will issue a supported router [though you haven't mentioned what the other router is that you have already got, and haven't clarified where the Huawei came from].
If it still works, you'd be charged for a replacement, unless within 4 months of the end of your contract and want to renew.
https://help-centre.talktalk.co.uk/Broadband/Security/Telecoms_Security_Act_Unsupported_devices
Message 3 of 6
Hi @Radiokenny
Are you saying that you cannot get the DG8041W to work at all, or are you saying this is just a port forwarding problem? Assuming the latter, please can you PM me (to preserve your privacy) a screenshot of the port forwarding rule that you are trying to set up.
Message 4 of 6
@KeithFrench
One for you, my friend?
Message 5 of 6
@Radiokenny
Have you missed something out after "from?"
