Port forwarding minecraft server
lgrimley03
Message 8 of 8
I have no idea what im doing wrong but no matter what i do i cant portfoward my minecraft server, when i go on portchecker it always says closed, ive gone through every way i can find and think of to try figure this out but i dont understand it.
i have 2 routers , the eero and a tenda ac2100, the eero is connected to the tenda and then the tenda to the rest of the ethernet devices and wireless devices, ive tried portfowarding with that and it still says closed so i tested it but connecting there pc/server straight to the eero and port fowarding it and it still says port closed
i really dont understand
7 REPLIES 7
Message 1 of 8
Thanks for updating your profile. There's a firmware update available for your eero. Could you try switching the ONT off for 30 minutes then reboot the eero and check if it makes any difference to port forwarding
Message 2 of 8
no
Message 3 of 8
Thanks for updating your profile but could you also please add your TalkTalk home telephone number or account number
Message 4 of 8
Hi Chris,
This is my first time trying it with talktalk provider, i use to be with bt about a year ago but i havent needed to make am minecraft server nor port foward it but this week i wanted too but it just doesnt seem to work to the slightest even withg every method ive seen from youtube or other forums to do with the subject
I would greatly appreciate your help with the matter
Message 5 of 8
Thanks for the information. Can you please update your community profile to include your:
  • Name
  • Telephone number
  • Alternative contact number
lgrimley03
Message 6 of 8
Hi Chris,
Chris-TalkTalk
Message 7 of 8
Hi Igrimley03,
Has this worked in the past?
