No Broadband
Lindseyhydes
Message 3 of 3
 I’m in N10 and my broadband has just dropped out completely…
I did a test and the fix said there were problems..
how do I find out how long this interruption will last..?
I work from home!!
thanks
Message 1 of 3
Hi @Lindseyhydes
Can I just check, is everything working ok this morning?
Message 2 of 3
You are in the staff's queue for a response, but in the meantime can you confirm if your router light is solid orange or is it flashing as if trying to connect.
Have you tried a pinhole reset of the router?. Insert a pin in the hole until it restarts.
For a quicker reply can you please ensure you have your personal information up to date in your profile including your TalkTalk landline phone number so your account can be traced. Link here - https://community.talktalk.co.uk/t5/user/myprofilepage/tab/personal-profile:personal-info
You can also add your account number in the private notes field, which only you and the support staff can view.
Please post back when done.
Thank you
