on 15-12-2023 05:04 PM
I have been having regular dropouts in my connection for over a week now. The speed is fine when it is working, but the connection drops at least 5-10 times per day.
on 18-12-2023 11:43 AM
Hi jcnporter
I'm so glad to hear this, thanks for letting us know 🙂
on 18-12-2023 11:40 AM
The engineer fixed the issue and after switching my router off for 30 minutes, speeds are now back to normal, so it looks like it is fixed.
on 18-12-2023 08:41 AM
Hi jcnporter
I'm sorry for the delay.
I can see that the fault has already been assigned to a line engineer this morning.
I will check on this fault again later this afternoon for additional updates.
on 16-12-2023 02:59 PM
2. What is the exact status of the lights on the front of the router when this happens?
3. If you have any wired connections, are they affected in the same way as wireless ones?
