Router intermittent disconnects - log: TR-069 connectivity(...) closed
Hoeggieonculus
Message 8 of 8
I am getting constant disconnects on our router - to the internet.  It seems happen from 2-3 mins and 10-15 mins between times.  I have noticed the following log line repeat when this happen.  Can someone help me determine what I can do to fix this problem.  thank you.
Heres the lines that repeat:
23.04.2022 07:30:06 Info SYS
TR-069 connectivity to (acs.talktalk.co.uk) has been closed
23.04.2022 07:30:02 Info DHCPC
The WAN DHCP client IP address 92.31.184.124
23.04.2022 07:29:44 Info DHCPC
WAN DHCP client (1) started
23.04.2022 07:29:41 Info XDSL
VDSL connectivity is up port 1
23.04.2022 07:29:14 Warning DHCPC
WAN DHCP client (1) stopped
7 REPLIES 7
Message 1 of 8
Hi Hoeggieonculus
That's great, thanks for letting us know.
Debbie 🙂
Message 2 of 8
Hello Debbie.
No problem.
I dont think We will need help with this thanks, as it's fixed.
After an engineer visited - improving our master socket, and presumably some fiddling in the exchange - we have a connection that is better than it was.
Thanks Also @KeithFrench for your input.
Message 3 of 8
Hi Hoeggieonculus
Sorry for the delay.
Do you still need help with this?
Hoeggieonculus
Message 4 of 8
For later reference, the firmware version is  : SG4K100130.
However, I think I will put this thread on ice, given a party(In our house) has got a good(or lucky) engineer to diagnose a fault on the local network, OUTSIDE of our house.
( I posted this thread initially after another engineer found the problem to be IN our rented property), so feel free to ignore this for now.  I will return to it and confirm what has happened later, to conclude or continue the thread. Thanks!
Message 5 of 8
They aim to respond within 48 hours (Monday - Friday), but if more urgent you can always try the Service Centre. The posts are responded to in time/date order, oldest first. Please try to avoid posting on here until TalkTalk have responded to you, otherwise, this will just put you further down the queue.
Message 6 of 8
Hi Thanks for the repsonse.
I am certain the device is a SagemCom Talktalk Wi-fi Hub
the device version is FAST 5364-3. T8
Message 7 of 8
What make/model of router is this? The TR069 connection is TalkTalk's remote management platform, it will not make your connection unstable.
