Router keeps moving to a busy channel, even though I manually change it to a less busy channel
MimoG
Message 11 of 11
Router keeps moving on to a busy channel, even after I manually change to a less busy channel
10 REPLIES 10
Message 1 of 11
Hi @MimoG
I've just checked your wireless stats. Have you connected all your devices on 2.4ghz?
MimoG
Message 2 of 11
There has been no change. It STILL keeps changing to a congested channel, even after I have manually changed it to a less busy channel. Giving me connectivity issues.
Message 3 of 11
Hi @MimoG
 If you do experience any further issues then please post back on this thread and let us know.
Message 4 of 11
@MimoG  Just checking back in to see how you're getting on?
Message 5 of 11
Message 6 of 11
Hi MimoG
How's the connection been? Do you still need help with this?
Message 7 of 11
Hi MimoG
Our Devices Team have asked if you can reboot the router and retest to see if you are still having issues with the wireless channels?
Message 8 of 11
Hi MimoG
Apologies for this.
I will ask our Devices Team to take a look at this for you and I will post back on this thread as soon as I have further information.
Message 9 of 11
Yes, and it also reactivates if the router is factory reset.
So it's something that will keep requiring a switch off from forum staff support as and when, @MimoG.
Divsec
Message 10 of 11
Hi @MimoG yes it's surprisingly called optimisation. It can be disabled by the team here but last I knew it reactivates every time the firmware is updated.
