Router not accepting connections
Mal2022
Message 21 of 21
Few weeks ago replaced router (Sagem SG4K100136) as previous kept dropping wifi. New router same problems but now wont accept any wireless connections. Tried turning off and leaving overnight/factory reset etc. PC wired ethernet connection no problem. The router is in good location away from electronics and there is a good wifi signal
Any suggestions welcome
20 REPLIES 20
Message 1 of 21
How are you getting on?
Mal2022
Message 2 of 21
OK Thanks
Message 3 of 21
Hi Mal2022
Thank you. If the connection works ok with this router then I will contact our devices team to investigate the issue you are experiencing the Sagemcom hub.
Mal2022
Message 4 of 21
Ok thanks - hopefully it will work
Message 5 of 21
Hi Mal2022
It's another Huawei router but a different model.
Ok, thanks @KeithFrench
Message 6 of 21
Hi @Debbie-TalkTalk I will send you a PM.
Mal2022
Message 7 of 21
Thanks will do - is a modern version of the Huawei HG633 ?
Message 8 of 21
Hi Mal2022
The Huawei hub is on its way, please allow 24-48hrs for this to arrive.
Mal2022
Message 9 of 21
I will try anything !!!
Message 10 of 21
Hi Mal2022
Would you like to try the Huawei WIFI hub?
Message 11 of 21
Hi @KeithFrench
This will be the new FW for the Sagemcom hubs after 130. We are rolling out smaller numbers of 136 at the moment.
What issues have you seen?
Mal2022
Message 12 of 21
The last router before the replacement was a Huawei HG633 which to be fair, I did not have any problems with - but the new improved router was sent......
Message 13 of 21
Hi @Anonymous This is another Sagemcom with the wrong firmware, it should not be running V136 as this has all sorts of issues.
Message 14 of 21
Hi Mal2022
Have you tried a Huawei WIFI hub to see how the connection compares?
Mal2022
Message 15 of 21
Information posted
Message 16 of 21
  • Name
  • Telephone number
  • Alternative contact number
Mal2022
Message 17 of 21
After literally 10 attempts it has finally connected but after a few minutes
has dropped again and won't reconnect
Message 18 of 21
Sagem SG4K100136
Mal2022
Message 19 of 21
Yes it is the same model
Message 20 of 21
I'm sorry to hear this. Can I just confirm, is the replacement router the same and model as the previous router? @KeithFrench - would you be able to offer any advice on the wireless please?
