Router not connecting to laptops
Ukgpr
Message 4 of 4
Hi, my talk talk router has kicked off my laptops and cannot reconnect. I have rebooted both laptops and no joy. The last time this happened I had to reboot the router 2 times to resolve, but this is not always practical.
3 REPLIES 3
Message 1 of 4
How are you getting on?
Message 2 of 4
Hi @Ukgpr
It is the devices (laptops) that connect to the router, not the other way around. Obviously, that does not help you though.
Slow speed, intermittent dropouts, breaks in the signal, no signal on some or all devices or no internet access might be caused by Wi-Fi interference from other local networks, which can also lead to a permanent reduction in speed. No ISP can be responsible for your local environment, this is mainly a byproduct of the popularity of Wi-Fi.
In other words, I try to help you optimise your Wi-Fi connection. If you would like me to help you, please can you specify the make/model of TalkTalk router that you are using?
Chris-TalkTalk
Message 3 of 4
Hi Ukgpr,
  • Name
  • Telephone number
  • Alternative contact number
