Shell Router broken, no replacement in sight. Incompetent, unhelpful CST
Callyroad
Message 2 of 2
On Friday 15th November, my broadband disconnected for no obvious reason, and after testing and resetting, the router you decided as it was a Shell router, you needed to send another one.
I am very unhappy that you appeared to have disconnected my router. However I was prepared to wait patiently over the weekend. Then on Monday one of your team called me to say a new router had been despatched on the 13th November – this is not possible, since that is two days before I raised the tech issue and complained. They then said they would dispatch another router. That was yesterday.
Now I have called again and they STILL cannot confirm that a router has been sent or not. I can’t be put through to anyone in the UK. This is outrageous incompetence. I have been without broadband at home now for five days.
Your call centre staff in south africa are incompetent, rude and unhelpful and they seem to know absolutely nothing.
I insist that someone – in the UK – contacts me immediately to work out how this can have gone so badly wrong.
I WILL be complaining to Ofcom about this, and the dispute resolution body.
1 REPLY 1
Chris-TalkTalk
Message 1 of 2
Hi Callyroad,
I'm sorry but you will need to speak the Shell migration team, I'm afraid we can only provide very limited support to Shell migration customer. If you call the migration team on 0345 172 0088, they'll be able to help.
