Slow Intenet speed
JaniceTeece
Message 3 of 3
Only getting 8mbps to the router instead of the guaranteed  18mbps. This has been like this for a week and a bit now.
Message 1 of 3
Hi JaniceTeece
Please can you add your TalkTalk landline number to your Community Profile, we can then take a look at this for you.
Skynet_TX
Message 2 of 3
Hi @JaniceTeece,
It would be worth going to the Service Centre to ‘run a live connection test’ on your line, this will indicate if there is currently a fault affecting your service. You can also access this from the ‘My Account’ site.
The TalkTalk Support Team on this community will be able to help, they will hopefully be able to respond to this post tomorrow.
