Monday - last edited Monday
For the past 24 hours I've had no WiFi. There are no green lights on the router just a solid red light where the status symbol is which sometimes disappears. I've tried all the troubleshooting advice which hasn't helped, I completed a connection test on TalkTalks website but it said there was no known issues with the router.
15 hours ago
Monday
Monday
That's great. Thank you very much for your help.
Monday
Hi @KieranJ
No problem 🙂
Let us know how you get on.
Monday
Yes that would be great thanks.
Monday
Hi @KieranJ
Thank you 🙂
I've completed a line test and this hasn't detected any line faults.
I think we should send a replacement router, are you happy for me to arrange this?
Monday
Thank you for the swift reply. I've added the details you requested to my profile.
Monday
Hi @KieranJ
Please can you add your name and TalkTalk landline number to your Community Profile, I can then take a look at this for you.
