System reset due to kernel panic
martynwjones
Message 7 of 7
Wifi is dropping out once per day. Off for about 2 minutes then auto resets.  New instalation last month.  Was with EE before and no issues.  I reviewed the User log and see this:
1981-01-01 00:00:10 [Error][Alarm-Log] AlarmID:104001,AlarmLevel:Error,Device reset. Cause: System reset due to kernel panic, Terminal:OTHER
2021-11-08 20:26:41 [Notice][Run-Log] SNTP has synchronized successfully, current time is [2021-11-08 20:26:41+00:00], uptime is [71s].
2021-11-08 20:26:41 [Critical][Config-Log] Terminal:ACS(62.24.243.161),Result:Success,Type:Set,InternetGatewayDevice.ManagementServer:,ConnectionRequestUsername:userid,ConnectionRequestPassword:-
2021-11-08 20:27:02 [Critical][Config-Log] Terminal:ACS(62.24.243.161),Result:Success,Type:Set,InternetGatewayDevice.ManagementServer:,PeriodicInformEnable:1,PeriodicInformInterval:86400,PeriodicInformTime:2021-11-08T20:27:02.101Z
2021-11-08 20:27:54 [Critical][Config-Log] Terminal:WEB(192.168.1.14),Result:Success,Type:Login,Username:admin
Is this a know error please?
Thanks everyone
Martyn Jones
6 REPLIES 6
Message 1 of 7
Hi martynwjones
You're welcome 🙂
martynwjones
Message 2 of 7
Many thanks for the rapid response !  I will monitor and let you know if I have any further issues.  Cheers 🙂
Martyn Jones
Message 3 of 7
Hi martynwjones
Apologies for this.
I've made a change to the firmware, please can you retest and let us know how the connection compares.
Message 4 of 7
Cool, they will pick this up as soon as they can, hopefully tomorrow.  🙂
martynwjones
Message 5 of 7
Thanks - I have just done that
Martyn Jones
Message 6 of 7
Hi @martynwjones it is a known error in certain cases with the Huawei DG8041W Hub. The support team here can arrange a fix, please make sure that your personal details including TalkTalk landline number and/or account number are complete on your community profile (click here) so that they can link your forum identity with your account and then wait for them to respond.
