on 03-09-2024 06:36 PM
please help my talktalk router keeps rebooting, sometimes 5 times a day.
[Error][Alarm-Log] AlarmID:104001,AlarmLevel:Error,Device reset. Cause: System reset due to kernel panic, Terminal:OTHER
this is driving me crazy.
thanks
on 17-09-2024 12:44 PM
Afternoon Mark,
I'm glad to hear this and thanks for letting us know 🙂
on 17-09-2024 12:43 PM
everything seems ok now I have added a separate Wi-Fi router to use for the smart devices. all devices show online at all time.
no issues at all.
thanks
on 17-09-2024 07:58 AM
Morning Mark,
How has your connection been over the last few days?
on 13-09-2024 08:20 AM
OK, just let us know if you experience any further problems
on 13-09-2024 08:11 AM
PC is on a wired network, same as all my cameras, then HDMI to tv.
only 1 smart device disconnected in the night and router seems faster to access, looks like it has settled down for now.
maybe it will be ok.
thanks for now....
on 13-09-2024 07:25 AM
Hi Mark,
I can't see any issues at our end, speeds look good. How does the windows PC connect to the TV and how does it connect to the router?
on 12-09-2024 04:58 PM
ok so router is ok if I pause NowTV. it also didnt crash until I started watching NOWTV if that helps, I am watching it on my TV via a windows 11 pc.
on 12-09-2024 04:52 PM
I have powered down for 15 mins, restarted, router is super slow when I log into it, yes slower than the slow that it was before, computer now keeps asking me if I want to close or wait. I wait. when I go to the logs it shows me one page, I click next page and it logs me out.
I try going to something else in the router and it logs me out. Not getting anywhere. even before this I keep getting notification from Tuya app saying device off line, then it comes back and another device goes offline, but its constant one device then another.
on 12-09-2024 03:36 PM
Power the router off for 2 minutes at the mains then back on and see if it lets you log in.
on 12-09-2024 03:27 PM
thanks, but now when I try to navigate the router, it randomly kicks me out back to log on page.
this is not good.
on 12-09-2024 03:12 PM
I've updated the router to the latest firmware, see if this is better.
on 12-09-2024 02:50 PM
just crashed and rebooted again, see log
| 12.09.2024 14:38:13 | Error | DNS | DNS name resolution failure (api.intelsa.intel.com) |
| 12.09.2024 14:34:04 | Warning | DHCPC | WAN DHCP client (1) stopped |
| 12.09.2024 14:33:13 | Error | DNS | DNS name resolution failure (api.intelsa.intel.com) |
| 12.09.2024 14:28:19 | Error | DNS | DNS name resolution failure (control-10eu.kebab.jp) |
| 12.09.2024 14:28:13 | Error | DNS | DNS name resolution failure (api.intelsa.intel.com) |
on 11-09-2024 07:09 AM
Hi Mark
If you do experience any further issues then please let us know.
on 10-09-2024 05:06 PM
no more kernel panic yet, it would be nice if the new router had Nat loop back like the old one as I have a few cameras.
it would also be nice if it came configured to work with smart home devices, none would connect but I have it working now
thanks
on 06-09-2024 12:27 PM
Hi Mark,
How are you getting on?
on 04-09-2024 12:18 PM
No problem 🙂
on 04-09-2024 12:17 PM
thank you, lets hope it sorts everything out.
on 04-09-2024 12:13 PM
Hi Mark,
I've ordered a replacement router. It should be with you within a couple of working days
on 04-09-2024 11:57 AM
yes I would love a new router. thanks
on 04-09-2024 11:54 AM
