TP-Link Archer D7 Test xDSL Synchronization Fail
marsneid
Message 5 of 5
I am trying to use the Archer D7 router as it potentially has a feww added features over the standard TalkTalk hub (USB harddisk option), but I can't connect to the internet. I have set the provider to TalkTalk  and entered my phome phone number xxxxxxx@taltalk.net but it keeps on failing to connect, Are there any further options I can look at?
4 REPLIES 4
Message 1 of 5
Did you get it working by following the fibre Instructuons, i e. No username?
Message 2 of 5
So why are you being asked for a username?
Message 3 of 5
Yes
Message 4 of 5
Are you using the recommended setting here?
https://community.talktalk.co.uk/t5/Articles/Set-up-a-non-TalkTalk-router/ta-p/2205383
