TalkTalk router firmware
Swade94
Message 11 of 11
I would like to know if there’s a way to update my router firmware, it says it’s last update was 2018, Is there a way I can do this?
Current firmware: v1.10t
Modem/Router: DSL-3782
10 REPLIES 10
Message 1 of 11
Hi Swade94
I'm so glad to hear this, thanks for letting us know 🙂
Message 2 of 11
Hi Debbie, it’s arrived today it’s night and day difference all around, thank you so much!
Message 3 of 11
Hi Swade94
Thank you 🙂
Message 4 of 11
Hi, I’ve just added the number. Thank you.
Message 5 of 11
Hi Swade94
I can send you a replacement router. Please can you add your TalkTalk landline number to your Community Profile.
Message 6 of 11
Before you hasten to do that wait for the support team here to respond, they will likely be able to swap the router out for you.
Message 7 of 11
The connection recently has started to deteriorate, it’s reached a point where I have to reset it every day. It’s what made me check the firmware and I thought maybe it’s outdated. I guess not much can be done, I’ll look into buying another.
Message 8 of 11
That is the latest version. Are you having any issues with the router?
Message 9 of 11
martswain
Message 10 of 11
EXACTLY what model router do you have and what is the firmware version ?
Anonymous User
