Turn off automatic channel optimisation
dboard11
Message 6 of 6
Hello, could you please help me turn off automatic channel optimisation?
Thank you.
5 REPLIES 5
Mandisa-TT
Message 1 of 6
Hi @dboard11 let us know if you still need assistance.
Message 2 of 6
That is true, however, most cases these days the problem is caused by something else, not WiFi optimisation. I can run an independent assessment of the state of your WiFi.
Slow speed, intermittent dropouts, breaks in the signal or no signal on some or all devices or no internet access might be caused by Wi-Fi interference from other local networks, which can also lead to a permanent reduction in speed. No ISP can be responsible for your local environment; this is mainly a byproduct of the popularity of Wifi.
Generally speaking, the 2.4GHz band suffers a lot more from interference than the much faster 5GHz band, but the 2.4GHz band can sometimes have a better range; however, this all depends on your local area.
In other words, I offer a free, impartial analysis of your Wi-Fi network and will try to help you optimise your Wi-Fi connection. The next stage involves sending out a guide to help you get me some important diagnostic results so that I can analyse them for you and recommend changes to your router configuration to solve them.
mandisa1-TT
Message 3 of 6
Thank you for the support @Gliwmaeden2
Gliwmaeden2
Message 4 of 6
@dboard11, it can't be done permanently any more - staff are no longer authorised to do this.
Stopped being an option about a year ago.
mandisa1-TT
Message 5 of 6
Hi there @dboard11
To turn off automatic channel optimization, follow these steps:
Log into the router settings.
Navigate to the Advanced Wireless settings.
Disable channel optimization.
Save settings
@KeithFrench Any assistance on this would be appreciated.
