on 09-12-2021 01:43 PM
"Conflict with internal service port" trying to port forward 80/443. DMZ doesn't seem to work (when configured, traffic to those ports doesn't reach the DMZ).
I notice similar posts to this over a long period of time. Is this fixed / ever going to be? Seems likely to be straightforward to add a router config option to set the service ports. Is the only fix to use a different router? In which case, do I need a modem solution from TT to enable this?
on 10-12-2021 06:48 AM
on 09-12-2021 04:09 PM
Hi @eLiam
This is a known firmware issue I reported to TalkTalk some time ago. Currently, you have two options, use a different external port for each, but then that port will need specifying in the URL used by anyone trying to access your web server. The other option is to ask TalkTalk if they will be prepared to swap it for the Sagemcom hub that does not suffer this problem.
on 09-12-2021 01:55 PM
Hi eLiam,
Does the information in this thread help with your issue - Port forwarding on DG8041W router - TalkTalk Help & Support
