on 09-12-2021 08:22 PM
My VPN to work stopped working yesterday. PPTN connection.
Please help
on 10-12-2021 08:19 AM
Hi pads1964
Thank you 🙂
on 10-12-2021 08:17 AM
Hi Debbie,
Thanks for the quick response.
I will update you, when I receive the alternative router.
on 10-12-2021 06:21 AM
Hi pads1964
I'm really sorry about this.
I have ordered you a different router and you should receive this within the next 24-48hrs.
on 09-12-2021 09:15 PM
They normally take 24-48 hours to arrive, and they do sometimes arrive on Saturdays and Sundays too, so hopefully you would get it pretty quickly if the staff do think that a replacement router is the best course of action.
on 09-12-2021 09:11 PM
OK, thanks.
Unfortunately that means I will not be able to perform my IT work in the evenings 😞
Hopefully it won't take too long to arrive.
on 09-12-2021 08:54 PM
Hmm, this seems to be happening to quite a few people, that is a new version of firmware for that router, and several people that are using the windows VPN seem to be having issues.
The staff here will be able to pick this up tomorrow, they may just suggest that they send you a new router of a different model.
on 09-12-2021 08:37 PM
Sagemcom FAST 5364 version SG4K100130
Microsoft Windows 10 VPN . PPTN connection. Has worked fine until 08/12/2021.
on 09-12-2021 08:31 PM
Hi @pads1964,
What model of router do you have ?
What VPN software are you using ?
