VPN Issue
crixal1s
Message 7 of 7
I can see many having a similar issue but here goes:
I haven't been working from home for a couple of months and I had no issues connecting to the work VPN server previously. I had to work from home today and imagine my surprise when I wasn't able to connect to the VPN and being told by our IT that all colleagues on TalkTalk are no longer able to do so either.
Most other issues seem to be resolved by a simple router change but my one seems to be a different one that most have reported:
Device Type:DG8041W
Description:EchoLife DG8041W Home Gateway
SN:2153035991QUKA011319
Hardware Version:I.1.01
Software Version:v1.05t
Could you please let me know if anything can be done as I do need this to work again urgently?
Thanks!
6 REPLIES 6
Message 1 of 7
Hi crixal1s
I'm so glad to hear this.
We didn't make any changes. If you do experience any further issues then please let us know.
crixal1s
Message 2 of 7
Hi Debbie,
Unsure what changed or if anything was done your end but suddenly my VPN connection is working again (wired and wireless).
Thanks a lot!
crixal1s
Message 3 of 7
Currently wired but no difference again.
Message 4 of 7
Hi crixal1s
Thanks for confirming this.
Have you also tried connecting wired to the router?
crixal1s
Message 5 of 7
Yes, didn't make any difference I am afraid
Message 6 of 7
Hi crixal1s
This router and firmware should work ok with VPN. Have you tried factory resetting the router using the pin hole reset for ten seconds?
