VPN connection suddenly stopped working
Lorraine44
Message 12 of 12
I use VPN to connect to my work computer and it suddenly stopped on Monday 26th Sept.  After doing a lot of investigating our IT guys say I need a Firmware update or a new router.  Talktalk customer service were not able to supply either.  Can you help please?
11 REPLIES 11
Message 1 of 12
I'm really glad to hear this and thanks for confirming 🙂
Lorraine44
Message 2 of 12
Hi Chris,
Thankyou! That seems to have worked.
Lorraine
Message 3 of 12
Hi Lorraine,
Yes the firmware update is complete. If you are still unable to connect to your VPN can you switch your router off and leave it off for at least 30 minutes then switch back on and retest
Lorraine44
Message 4 of 12
Hi Chris,
Has the upgrade been completed?  Is there any action I need to take as it's still blocking the VPN?
Lorraine
Message 5 of 12
OK, I'll start the upgrade now, please don't switch off your router
Message 6 of 12
Hi CHris,
Yes please go ahead.
Thanks,
Lorraine
Message 7 of 12
The firmware update can take up to 20 minutes to compete, would you like me to start it now?
Message 8 of 12
Hi Chris,
Yes that would be good, thanks.
Lorraine
Message 9 of 12
Thanks Lorraine. We can try a different firmware version, would you like to give this a try?
Message 10 of 12
Hi Chris,
Info updated on profile, thanks.
Lorraine
Chris-TalkTalk
Message 11 of 12
Hi Lorraine,
  • Name
  • Telephone number
  • Alternative contact number
