VPN issue
Pandast1
Message 5 of 5
I am trying to use my VPN but it doesn’t work on TalkTalk. It works on other broadbands.
Device version: FAST 5364-3 TB
Thank you
4 REPLIES 4
Message 1 of 5
How are you getting on? Do you still need help with this?
Message 2 of 5
OK thanks. We can try a different firmware version, would you like to give this a try?
Message 3 of 5
It says PPTP port is limited on the router.
This is the first time trying this VPN on TalkTalk but it worked on my old broadband.
Chris-TalkTalk
Message 4 of 5
Hi Pandast1,
Welcome to the Community. What happens when you try to connect to your VPN, do you get an error message?
Has it worked in the past?
