VPN not working SGK100130
catie_v
Message 7 of 7
My work laptop will no longer connect to the VPN. Apparently it is because of the router version SGK100130 I have at home. Please advise!
Catie Vacher
6 REPLIES 6
Message 1 of 7
Hi catie_v
I've made a change to your router firmware, please can you retest and let us know how the connection compares?
Message 2 of 7
I have done this now
Catie Vacher
Message 3 of 7
Hi catie_v
Please can you also add your TalkTalk landline number to your Community Profile.
Skynet_TX
Message 4 of 7
Hi @catie_v,
The support team here on the community probably won't be around until Monday now. If you are using the built in Windows 10/11 VPN then the version of firmware you are using can cause problems, the support team here will probably be able to make some changes to your router settings, or apply a different firmware version when they return on Monday.
Message 5 of 7
Hi Debbie
Have done this now, thanks
Catie Vacher
Message 6 of 7
Hi catie_v
Please can you add your name and TalkTalk landline number to your Community Profile, we can then take a look at this for you.
