on 04-01-2025 02:14 PM
I am trying to use a VPN, this was working to a few days ago and now it’s not. If I switch the VPN off I can continue as normal but VPN is required for some tasks. Please advise.
on 09-01-2025 12:49 PM
Could you switch the router off and leave it off for at least 30 minutes, then switch back on and retest. Please let us know how you get on
on 09-01-2025 11:59 AM
The VPN connects but getting errors on playback.
on 09-01-2025 11:53 AM
Could I just ask what happens when you try to connect to the VPN, do you get an error message?
on 09-01-2025 11:33 AM
Done 🙂
on 09-01-2025 06:52 AM
We'll then look into this further. Please do not post this information on this thread. Once you've updated your profile please post in your topic to confirm it's updated.
on 08-01-2025 08:32 PM
Yes please.
on 08-01-2025 07:51 AM
Hi catrinhollings
Do you still need help with this?
on 05-01-2025 11:27 AM
Thanks for that. There are no known VPN issues with V206 firmware.
Those two VPN clients that you mentioned Bright & Free VPN, what type of device are you running those on? If they are compatible with any of my devices, I will test them.
on 04-01-2025 05:10 PM
SG4K100206 ??
I don’t know what you mean by VPN Protocol.
on 04-01-2025 04:27 PM
Alas that is the post code for Sagemcom in France! However, that is close enough, you either have the FAST 5364 or 5464.
To find the firmware, go the router's login page at 192.168.1.1. There's no need to login, the firmware is at the bottom left of the page (they call it software).
Your VPN client is a bit vague. What VPN protocol do they use?
on 04-01-2025 03:34 PM
Sagemcom
CS 50001
2. What firmware version is it running?
I’m not sure how to find this.
3. Which VPN client are you trying to use?
tried a few, bright vpn on tv & free vpn
on 04-01-2025 02:54 PM
I have tested all of the VPN client/server combinations that I can & currently do not know of any ones that do not work. Please can you elaborate by answering these few questions:-
