VPN wont connect
Vcb1981
Message 9 of 9
Hi, ive just got off the phone with my office IT person. I have recently been trying to connect to my works VPN - however we can not get it to connect, my IT guy has tried all sorts of settings and he's come to the conclusion that I either need a new router or firmware needs updating - my firware is SG4K100136...is there an update? My router is a FAST5364-3.
How do i go about getting either firmware update or a new router as i currently am unable to work!! i used to be able to "remote" into my desktop but that option is no longer available so have to connect via VPN.
Thanks in advance.
8 REPLIES 8
Message 1 of 9
Hi Vcb1981
Is everything working ok now?
Message 2 of 9
Hi Chris....i think this has solved it....just a problem now we think at works end!
Thank you for your help
Message 3 of 9
Hi Vcb1981,
How are you getting on, has the firmware update resolved the issue?
Message 4 of 9
Ok, I'll start it now, please don't switch off your router
Message 5 of 9
Yes this is fine - thank you.
Message 6 of 9
It's OK, I'll start the firmware update remotely, is it OK to start it now, it can take up to 10 minutes to complete?
Vcb1981
Message 7 of 9
Hi Chris - yes please, that would be great! How do i do this? Im not tech savy!
Chris-TalkTalk
Message 8 of 9
Hi Vcb1981,
We can update your firmware, would you like to give this a try?
