Very Slow Broadband Upload
on 17-08-2022 05:24 PM
Message 31 of 31
I have been having ongoing problems with broadband speed, particularly with upload speed. I have spend hours on the phone with TalkTalk Technical Service, every time having to try the same routines of turning router off then on, resetting, disconnecting devices and so it goes on.
In 2021 I was experiencing problems with the Huawei router disconnecting repeatedly. I was told a firmware update was on its way. But at least I was getting my agreed upload speed of 2.2mbps.
Changing to a Sagem Router stopped the drop outs, well actually it reconnected if it did drop out, but at the expense of speed. I now get 17mbps download (13mbps guaranteed on Fibre 35), but only 1.4mbps upload (I am told I should get 2.2 / 2.4). 1.4 is not enough for Zoom calls, etc.
So is it the router again? I am also over 1km from the cabinet, and many more houses have been built in the area. I do have a cabinet around the corner, but apparently I cannot be connected to it.
Any suggestions on if the router may be the fault? Interestingly TalkTalk Tech Service say they can see 2.2mbps at my router, but when we look at the router dashboard, it reports back an orange signal with 1.7mbps!
Andrew
Labels:
- Labels:
Upload speeds
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
30 REPLIES 30
on 19-08-2022 11:03 AM
Message 21 of 31
Hi Chris,
Yes, just disconnected the phone line and turned router off. (Now running on my 4G MiFi)
Andrew
Andrew
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 19-08-2022 10:39 AM
Message 22 of 31
OK, could you just temporarily disconnect the telephone then switch the router off for 30 minutes, then switch back on and check to see if the speed has improved
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 19-08-2022 10:20 AM
Message 23 of 31
Hi Chris,
No, no issues with the phone line. Although to be honest we rarely use it. It is only in place because it is the only phone number my aged mother can remember 😊
Best wishes,
Andrew
Andrew
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 19-08-2022 10:10 AM
Message 24 of 31
Thanks for the information. Are you experiencing any problems with your telephone service, any noise on the line?
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 19-08-2022 09:57 AM
Message 25 of 31
Hi Chris,
Sorry I have been responding incorrectly, please see below.
We have just the one phone socket, the master one.
Although if it makes any difference, we have one cable coming to the property, which splits to feed both us and our neighbour who is also a TalkTalk customer.
Our master socket feeds a single landline phone and our TalkTalk router.
Best wishes,
Andrew
Andrew
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 19-08-2022 09:56 AM
Message 26 of 31
Hi Michelle,
I think I responded in the wrong place.
Thanks for your reply. Yes when we had problems last year before the router was replaced TalkTalk sent Openreach who replaced the cable on the outside of the property and fitted a new Master Socket just inside where the cable reaches the outer wall.
When GigaClear put their fibre in the road, they cut the Openreach cable, and when Openreach came along the said the connector was full of water any so probably a cause of signal dropping out. This is all repaired now.
When Tech Support helped last time they had me running directly into the 'test socket' behind the face plate on the master socket . No joy that time.
Please let me know what I can do next.
Andrew
Andrew
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 19-08-2022 09:52 AM
Message 27 of 31
Hi Chris,
Best wishes,
Andrew
Andrew
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 19-08-2022 07:50 AM
Message 28 of 31
Hi Andrew,
How many telephone sockets do you have?
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 18-08-2022 03:47 PM
Message 29 of 31
Hi Michelle,
When Tech Support helped last time they had me running directly into the master socket with filters. No joy that time.
Andrew
Andrew
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 18-08-2022 07:11 AM
Message 30 of 31
I'm sorry to hear this and I will take a look now. I've run a test on the line which hasn't detected a fault. Does your main socket have a test socket please?
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- « Previous
- 1
- 2
- Next »
Related Content
- PC Running Slow - Wi-Fi Issue - Will Full Fibre Solve It? in Broadband
- Slow Upload Speed on FTTC Connection in Fibre
- Fibre 65 lagging, discconections, slowing down, throttling? in Broadband
- upgrading old tv box in TV
- Talktalk disconnected a vulnerable persons internet due to system cancellation in Broadband
