on 29-06-2022 01:13 PM
I've been having issues over the last couple of months with a number of services that I'd put down to sketchy wifi, but now I've typed them all in a row above it looks like it may be a UDP issue. Did anything happen a couple of months ago that may have caused an issue?
My hardware and software versions
Hardware VersionSoftware VersionGUI Version
| FAST5364 3.00 |
| SG4K100136 |
| 5.6.1 |
on 04-07-2022 06:13 AM
Hi abitofcode
If you do experience any further issues then please let us know.
on 01-07-2022 05:42 PM
A factory reset has fixed it, everything back to normal. All Whats app, Ring doorbell, Xbox and discord connectivity issues gone. Should have stuck to my usual 3 step plan. XD
1. Switch everything off and on again.
2. Switch everything off, then on again after 30 minutes.
3. Factory reset.
on 30-06-2022 11:56 AM
Hi abitofcode
The only recent change has been the firmware update to 136. Would you like me to test a different firmware version to see how the connection compares?
