Wi-Fi Hub version SG4K100136 - Devices Unreachable
Grant
Chat Champion
Message 9 of 9
Some devices disappear from my network after a day or two and the only way to get them back again is to reboot the router (rebooting the affected devices doesn't fix the issue). I first noticed this issue in March/April 2022 when I believe the router updated to version SG4K100136. I am hoping to find out if this is a known issue or if there are any settings that can be tweaked or an update that can be applied.
Examples of devices 'disappearing':
  • Soundbars and Chromecasts stops showing in cast selection lists.
  • AirPrint printer stops showing up on iOS when trying to print.
  • Printer web UI stops being reachable using it's IP address.
This isn't a problem with the wifi strength or interference as these devices are all in the same room and accessing the internet from laptop/tablet is unaffected.
Thanks for any help in advance!
8 REPLIES 8
Message 1 of 9
I'm really glad to hear this. I'm just sending you a short survey via a PM now.
Grant
Chat Champion
Message 2 of 9
Hi @Debbie-TalkTalk and @KeithFrench,
Thanks both for you're help. Since switching off the WIFI optimisation, everything has been working great!
No additional assistance needed 😀
Message 3 of 9
Do you still want my help?
Message 4 of 9
Hi Grant
How has the connection been?
Message 5 of 9
Hi Grant
The WIFI optimisation has now been switched off. Please let us know how you get on.
Message 6 of 9
Hi Debbie,
 Yes, please can you disable Wi-Fi Optimisation on my router as suggested by Keith. I suspect the automatic channel switching is causing the problems I’m facing.
Message 7 of 9
Hi Grant
Sorry for the delay.
I can see that Keith has offered his support and advice. Do you still need help with this?
Message 8 of 9
It may not be electrical interference, but if they are all connected to WiFi, it could very easily be WiFi interference, which is not the same thing at all.
Have you had TalkTalk’s Wi-Fi optimisation disabled on your Sagemcom FAST5364 router? When this is enabled, as it is by default, it has the power to override any Wi-Fi configuration changes that I might suggest that you need to make. This will not help rectify this type of problem if Wi-Fi Optimisation is allowed to change my suggested settings. Only TalkTalk can do this for you, you cannot do it yourself. If not, just request they disable this for you in your reply.
The next stage involves sending out a guide to you to help you get me some important diagnostic results so that I can analyse them for you and recommend changes to your router configuration to solve them.
