Wi-Fi calling
ALWhite
Message 7 of 7
Wi-Fi calling has stopped working and everything points to the router which was restarted at 3:00am, ie not by me and there wasn't a power cut.  What have TalkTalk done?
6 REPLIES 6
Anonymous User
Message 1 of 7
Thanks for confirming and I will feed this back.
Message 2 of 7
Hi Michelle
The problem was caused by a firmware upgrade.  I have done a factory reset and everything is working now.  When I re-entered my settings the only difference was that an apostrophe is no longer allowed in the Friendly Name field.  Could this have caused the glitch?  I just hope that future firmware upgrades don't upset anything - at least I know what to do.
Thanks,    Adam
Anonymous User
Message 3 of 7
Thank you. I've run a test on the line now which has hasn't detected a fault and the connection stats look ok. Have you tried factory resetting the router and then re-setting the router back up again?
Message 4 of 7
My contact details have been updated.
Anonymous User
Message 5 of 7
  • Name
  • Telephone number
  • Alternative contact number
Message 6 of 7
I will ask TalkTalk to investigate this for you.
Anonymous User
