on 04-04-2023 10:01 AM
Sagemcom 2019 router
Constantly dropping WiFi connections recently.
No change in connected devices.
Wired connections work fine.
Re-started, etc, no change.
Would it be possible to get a replacement router please?
on 04-04-2023 10:16 AM
Hi Matt
Thank you 🙂
on 04-04-2023 10:12 AM
Details added.
Please note I do not use the landline phone - use mobile number if needed.
on 04-04-2023 10:05 AM
Hi Matt
Please can you add your name and TalkTalk landline number to your Community Profile, I can then send you a replacement router.
