Wifi keeps dropping!!
JenniferJackson9x
Message 3 of 3
I work from home, which relies on my broadband connection so I can make calls for my company through WiFi. However my WiFi keeps dropping then coming back on continuously throughout the day and has done since I got Talk Talk WiFi! It's appalling and making me get into trouble at work as it drops the calls as if I've hung up on a customer! Seriously need to sort your services out its disgusting, especially with the price!
I've tried doing a diagnosis test and it says everything is fine...well its clearly not is it?!
Message 1 of 3
How are you getting on?
Message 2 of 3
Slow speed, intermittent dropouts, breaks in the signal, no signal on some or all devices or no internet access might be caused by Wi-Fi interference from other local networks, which can also lead to a permanent reduction in speed. No ISP can be responsible for your local environment, this is mainly a by-product of the popularity of Wi-Fi.
If you would like me to help you, please can you specify the make/model of TalkTalk router that you are using?
