Sunday
I am very unhappy with TalkTalk. My mother has a fibre 65 standard router and it keeps dropping devices, dropping connection and generally being rubbish. I have run every test on the support website, reset it a load of times, turned it off for 20 minutes. I went on livechat and they say there is nothing wrong with it. TalkTalk are very difficult to deal with as its very hard to speak to a person on the phone (dial a bot end up hanging up on you) and their webchat agents take about 5 minutes to respons to every message. If any one has a fix or advice, I would be very grateful
Sunday
Sunday
Thanks for your fast reply Keith.
The model is a Sagecom Fast F5364-3.T8
I don't live with her so I've not been able to check the lights and the first she knows of the dropping connections is when the ring doorbell doesn't work or her netflix buffers. I'll try and see what happens with the lights.
She doesn't have any wired connections and everything is WiFi.
Sunday
1. What make/model of router does she have - not just a "standard router" there are several, (these details will be on a label on the rear or underside of it)?
2. What is the exact status of the lights on the front of the router when this happens?
3. If she has any wired connections, are they affected in the same way as wireless ones?
