WiFi signal keeps dropping
Altafica
Message 12 of 12
I have fibre 65. My WiFi keeps dropping out. This is xausing me to loose connection on my tablet. I sit 10ft away from router and still happens. Ring doorbell says connection low, that is 20ft away. And despite buying a booster to put in bedroom it still drops out.
I've been on chat and have been told there are no issues numerous times, they have run through the process of checking the connection with me, told me my router should be clear of obstructions, it is.
I have done everything and still keeps dropping. Starting to getting to the stage of changing providers. I've only got a small house so surley it should work.
Anybody got some advice? Please no technical answers plain English.
11 REPLIES 11
Message 1 of 12
Message 2 of 12
Hi @Altafica
I've ordered a replacement router and a WIFI booster, please allow 24-48hrs for this to arrive.
Let us know how the connection compares.
Altafica
Message 3 of 12
That would be good thank you, is there a booster you supply that will help the week signal upstairs?
Message 4 of 12
Hi @Altafica
Apologies for the delay.
Would you like me to send a replacement router for testing?
Message 5 of 12
Thanks. Your replies will help move things along a bit now, so I'll re-escalate this thread for staff to follow up, @Altafica
Look out for their response during the day.
Altafica
Message 6 of 12
Yes just wifi and the router is about 3/4 yrs old
Altafica
Message 7 of 12
They asked me to update my profile which i did
Message 8 of 12
@Altafica, please reply to staff on this thread.
They would have expected a response from you last week, if possible.
I'll remove your duplicate thread.
Message 9 of 12
Good morning,
Thank you. I've run a test on your line now which is clear. Can I just check, is it only the wireless connection which is dropping? Do you have any devices connected wired? How long have you had this router for please?
Altafica
Message 10 of 12
I have updated everything, any ideas
Message 11 of 12
  • Name
  • Telephone number or Account number
  • Alternative contact number
